• 16.11.2026, 04:17
fox3
How to analyze log data in aquasuite?
vendredi 20 mars 2009, 04:26
The title says it all. I am not sure what I am doing wrong. I have made individual files for the tubemeter, pumps and aquaero. I check them and they are accepting data and updating every 5 seconds, but not to the *edit* aquasuite data log graph. I am missing something and hope someone can point me in the right direction as to what button I may need to activate or whatever I am missing.
Ce message a été modifié 1 fois. Dernière modification effectuée par "fox3" (20 mars 2009, 05:30)
Top_Nurse
vendredi 20 mars 2009, 05:00
I don't believe the Aquaero can data process. I think you need to export the data to a number cruncher and then you can use the data in the USB-LCD mode If I am thinking about this correctly.
fox3
vendredi 20 mars 2009, 05:29
Oops my bad :pinch: , I meant to say it does not update to the aquasuite software and typed aquaero in error.
I am trying to get graphs to show in the analyze log data graph window in aquasuite but for whatever reason it does not print any data points or graph lines. I have checked the files and they are receiving and updating data so I must be missing somwething in the software log data to aquasuite
Top_Nurse
vendredi 20 mars 2009, 06:30
Never did this, but Aquasuite => XML & Log Data => Log On/Off
=> LCD data output => LCD data output?
Go here for the real skinny: http://www.hardforum.com/showthread.php?t=909050
vendredi 20 mars 2009, 10:54
Go to Extras -> Analyze Log Data, selecta device and click on the load data button. You can now drag and drop the values into the charts area.
fox3
vendredi 20 mars 2009, 15:25
That works, I am now getting data to graph ... Thanx :thumbup:
