• 22.11.2026, 21:39
Top_Nurse
samedi 21 mars 2009, 00:00
A solution to the water temp probe if you cannot fit a tee can be found in the german speaking watercooling forum. I saw an inline water sensor yesterday there, its sorta like a doughnut shaped fitting with female threads on bothe ends for fittings. The sensor is part of the fitting and is very streamlined. You might wanna chack that one out. HTH.
If this is what you are referring to I don't think it will work inside the Aquaduct as it adds too much fittings. However, great find! I want to add a couple on to my order as I am sure I will find a use for them in Feeding Frenzy. :D
Top_Nurse
mardi 24 mars 2009, 05:08
One of the things about the Aquaduct that sooner or later becomes apparent is how the hell are you going to stuff it all back in. If point of fact, after having it all apart for a few months I tried putting it back the same way I took it apart. No way.... beginning to wonder if they put this all together in a cold room.
So matters stood until I started back on this project. Once you start thinking out of the box (no pun intended) on one thing you are more inclined to do something else that on the face of it seems somewhat wacky. The problem was getting back in that silver colored mesh as there just didn't seem to be the same amount of room putting it back in. One side of the mesh was easy, but getting the other side in was exasperating to say the least. Then it suddenly occurred to me that I could put it back together in a different way seeing how as I already had moved the flow meter and changed the sides around. :thumbsup:
So now the back side plate holds in the silver back mesh and is screwed into the radiator. The front plate holds the silver front mesh and the fans. Then I can just slip the front plate back in without all the hassles of trying to get all the holes to line up. Don't know if there will be any vibration from the fans just sitting next to the radiator, but I don't think it will as it is still pretty tight in there. BTW, I wouldn't recommend modding the Aquaduct unless you like tinkering and playing with complex puzzles. ;)
Sliding the front piece into the main housing.
Ready to put in the Aquaero, but wait! It's time to take it all apart again which is another story. :D
Well I guess I can give you a little hint. It's jigsaw time. 8o
Ce message a été modifié 1 fois. Dernière modification effectuée par "Top_Nurse" (24 mars 2009, 05:11)
