• 09.10.2026, 17:14
phenomen
How much coolant I need for Aquaduct 369XT mark III
samedi 4 avril 2009, 15:21
Could you please tell me how much coolant do I need to fill the Aquaduct 360XT mark III, what kind of water is better to use, i.g. tap, boiled, drinking, distilled etc, and what are water/ACfluid mixture propotions?
Top_Nurse
samedi 4 avril 2009, 17:20
Welcome to the AC Forum :D
2% is the correct mixture of AC Fluid. No more no less. More is DEFINITELY not better!
Use common distilled water. My suggestion is make up a 2% mixture based on the size of the AC fluid bottle you have. Any extra mixed solution can be capped off and used to top off your system as you lose coolant.
The other option is to carefully measure the exact amount of distilled water added (in CC's) to charge your Aquaduct. Then add in a enough AC Fluid (use of a syringe graduated in CC's) to give yourself a 2% mixture.
Ce message a été modifié 2 fois. Dernière modification effectuée par "Top_Nurse" (4 avril 2009, 17:23)
phenomen
samedi 4 avril 2009, 18:32
Thanks a lot.
