• 10.10.2026, 22:51
smoothy
Help! Problems with aquastream
mercredi 13 mai 2009, 10:20
Hello,
THis is the first water loop i have ever constructed. so i read some noob guides and all was going well. i had a little leak on one of the fittings (i hadnt put the tube all the way in).
so i was ready to fire up the pump. however when i did nothing happened. i could see a red light on the pump, so i performed the reset described in the manual with the jumper, but still nothing happens and i get the red light.
any help will be massively appreciated!!!!!!!!
thanks
Defence1
jeudi 14 mai 2009, 15:13
Are you sure that the USB Cable is in the right direction ? Has the pump the power connector inserted in the right way and completely ?
Mein System:
