• 18.11.2026, 07:58
dhc0329
Please help! Only getting tiny bit of water flow with Aquastream Pump.
samedi 20 juin 2009, 09:08
I was running 3x120mm radiator (swiftech) on top of case and only cpu water and north bridge water block
with EK dual 5.25" bay reservoir....it was running fine but today I just added the koolance flow sensor...
after that nothing but disaster and I still can't get the water to flow....I spent all day shaking lian-li case trying
get the water to flow ..nothing help. Thinking it was koolance which caused this havoc so I even took it out.
Only way I can get the serious water flow is t have the pump directly connected to reservoir ONLY.
Do you think aquastream xt pump's not strong enough handle triple rad on top and two water block?
Ce message a été modifié 3 fois. Dernière modification effectuée par "dhc0329" (20 juin 2009, 09:11)
samedi 20 juin 2009, 13:46
Maybe you should check the impeller and axis.
Which values do you get in the aquasuite?
dhc0329
dimanche 21 juin 2009, 05:43
Thanks for your input but it was the coolant which caused the low flow rate. I am using Fluid XP+ Ultra LT w/ z7 and I now have to dilute the coolant with distilled water to get the substantial water flow. It used to be fine with the coolant alone....but now very small water flow. I am going 25:75 (coolant to water) and I am afraid I am not protected against corrosion and algae..
Before when it was working with the coolant I used to get around 77~78 and now with most of it water I get around 80.9 on aquasuite.
Ce message a été modifié 1 fois. Dernière modification effectuée par "dhc0329" (21 juin 2009, 05:46)
Discussions similaires
