• 05.10.2026, 08:52
Cyberdyne
Whether repair my pump?
mardi 11 août 2009, 18:02
Confronted with an issue. Improperly connected cable USB pulling the +5 V is on the other connector (Pin 4 D-). Then, of course, ceased to operate the software. I want to ask - my pump is beyond repair or electronics will not recover?
I lifted the hood and checked all the diodes. This diode was burned. Unfortunately, I do not know what the face value can be replaced. Here is his picture:
Please forgive me for my English - it is not my native language. I look forward to a reply.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Cyberdyne" (11 août 2009, 18:06)
Cyberdyne
mercredi 19 août 2009, 11:32
Defence1
vendredi 21 août 2009, 08:44
send it over to Aqua Computer, they can repair your pump. you can fix it even by yourself, simply change the diode.. The type can be named by Aqua Computer....
Mein System:
Cyberdyne
lundi 24 août 2009, 18:03
Thanks, I'll try to replace the diode itself. Are transferred to other countries are very far (and expensive).
Cyberdyne
lundi 24 août 2009, 18:07
Sven - thank you for additional information, I hope it will help
PvHooijdonk
mardi 25 août 2009, 14:17
The same thing happened to me some time ago.
Due to the fact that I did not notice in time that the colouring of the usb wiring was different than standard.
I tried to change the zener-diodes myself but was unsuccesful.
I ended up buying a replacement print plate for the pump via AC.
Professional Crasher :thumbsup:
kolsols
samedi 12 septembre 2009, 07:54
yes pf course simply replace your burnt diode with a new one and your pump would be fine.
Cyberdyne
lundi 14 septembre 2009, 20:56
I ordered a new diode - it will be soon to come. After replacing the diode, I will inform the result of repair
mans123
jeudi 24 septembre 2009, 09:06
hope it would be fine.
copcop
lundi 12 octobre 2009, 11:53
I think you should buy a new one instead of repairing it. :P
Top_Nurse
mardi 13 octobre 2009, 03:06
Why? There easy to fix. :thumbsup:
funkyfresh123
vendredi 30 octobre 2009, 10:54
just try to repair it...as it would be cost effective.
Cyberdyne
dimanche 8 novembre 2009, 10:16
Replacing the diode has not helped. Died controller (((
The controller has been filled with resin. Had some work to clean it.
The question now is - if I changed to a working chip (ATMEL), will need special firmware or will be enough this - aquastream XT-Firmware 1.09, DIY-Flasher?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Cyberdyne" (8 novembre 2009, 10:29)
lundi 9 novembre 2009, 16:35
That will not work in any way...
You will need a completley different firmware.
brianmoore123
mercredi 11 novembre 2009, 11:55
I think someone has already advised you not try to repair
