• 10.10.2026, 19:53
Pumpkin
Aqua COmputer Flow Sensor Cable
jeudi 3 septembre 2009, 12:12
Hi does anyone know what type of connector is used for the above cable that connects to the A.C flow sensor.
I wish to buy one in black as I will be sleeving all my cables in black :)
Ce message a été modifié 3 fois. Dernière modification effectuée par "Pumpkin" (3 septembre 2009, 12:14)
Top_Nurse
vendredi 4 septembre 2009, 10:35
A simple three wire cable. Which flow meter are you using and what are you hooking it up to?
Pumpkin
lundi 7 septembre 2009, 16:28
I have the Aquacomputer flow sensor and also the aqua computer cable but the connector on the end of the cable that goes into the aqua computer high flow sensor is white and not your standard size connector (i.e female fan connector head). I wish to buy a black version of the header.
Top_Nurse
mardi 8 septembre 2009, 12:08
Paint it or dye it. That connector can be hard to find in black. However, you might try Allied Electronics or digiKey.
