• 22.11.2026, 00:37
> Evil E. <
Best method to hold rubber gaskets in place ?
lundi 5 octobre 2009, 19:18
Simple question, difficult task :
What's the best way to place and keep large rubber gaskets (also called O-rings) in place, like the ones you can find in GPU blocks, so that you can properly attach the cover plate on the block without the gasket jumping out of its indentation ?
Shoggy : perhaps you can tell us all how it is done at AquaComputer and/or give us some inside hints and tips ? :)
Top_Nurse
lundi 5 octobre 2009, 19:41
Go buy some liquid glycerin (I used mineral oil). Apply to o-ring and set in groove. Shoggy told me this years ago and a bottle of the stuff will last you a long time.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Top_Nurse" (5 octobre 2009, 20:46)
ryan123
lundi 19 octobre 2009, 13:43
great idea...you should adopt it to keep your gaskets in place.
boatman
lundi 26 octobre 2009, 12:06
thanks for your useful tip
Discussions similaires
