• 13.11.2026, 00:29
scarpetta3
Two aquaero
jeudi 22 octobre 2009, 18:23
Hi guys, I understand that two tubemeter cannot be connect to a single aquaero. It's right?
If it is, can i connect to my pc more than 1 aquero? For example 2?
If the answer is "yes", I have 12 temperature sensors, 8 fan channel, two tubemeter 2 flowmeter that i can attach to them, is it right?
Another question: how all this things appear in the aquasuite? How can I manage all the things? Are there another label for each aquaero?
I hope that I explain well my question.
Thanx.
Reagards.
jeudi 22 octobre 2009, 19:26
You can connect hundreds of our devices to one PC. Every device will get it's own tab within the aquasuite so you can switch between them.
scarpetta3
jeudi 22 octobre 2009, 21:20
Ok.
Only another question, I see in the software a tab that it's label with aquastream, but I don't want to install two aquastream, I want to install a two laing with relative poweradjust.
My question is: in which label tha laing come? the same or another? And wich parameters can I set?
Thank you very much for the answer and congrats for your extremely competitve and complete software/hardware.
b0nez
vendredi 23 octobre 2009, 18:48
Download the Aquasuite and try the build in testmodus.
:rolleyes:
scarpetta3
samedi 24 octobre 2009, 00:48
Ok, thnx. Now all it's clear.
Congrats for all. All perfect.
insitu46
samedi 24 octobre 2009, 20:17
Gosh, I tried connecting two Aquaeros to one PC several months ago and my recollection is that Aquasuite could only see one of them.
Should I try this again?
mercredi 28 octobre 2009, 12:12
That should be normally no problem so you should try it again.
Do both work correctly when you connect them alone?
Discussions similaires
