• 10.10.2026, 15:20
Tibici
Huge difference of cooling between the 2 GPUs of the ATI HD5970
mercredi 14 avril 2010, 22:25
Hi everybody,
I have the aquaduct 720XT and a GPU Block aquagratiX for HD 5970 (2x RV870) standard (not with Nickel plates). I've got an important difference of cooling between the 2 GPUs. Using games or stress tools like FurMark, I reach 60°C for GPU1 and 100°C for GPU2. Even in the idle state, I've got GPU1=44°C and GPU2=54°C.
Water T°C is around 29°C. The graphic card is from MSI.
I've used Noctua Thermal compound and checked that the compound is set similarly on the 2 GPUs and Memory chips (as explained in the documentation).
Is this a known issue or do you have any advice for me?
Thank you guys,
jeudi 15 avril 2010, 19:58
Do you know if you own the Rev. 2 blocks? They have a small Rev. 2 engraving at the base near one of the GPU surfaces. Can't be overseen if it is there.
Tibici
jeudi 15 avril 2010, 21:15
Hi Sven,
I can't see any engraving on the external side of the waterblock. Should I unmount it from the graphic card to see it?
I can read "Stand 12/2009" into the documentation delivered with the block. It has been shipped to me on February, 15th 2010.
Its reference is n° 23483 in the Shop: http://shop.aquacomputer.de/product_info…roducts_id=2409
Thanks,
drbo
mercredi 21 avril 2010, 22:45
For me it seem that your GPU2 does not have good enough contact with the cooler.
I have the same waterblock, with an Sapphire HD5970 OC.
I run watertemps of 40/44 idle and 61/61 at full stress.
The GPU VRM, runs at 42/43 idle, 72/79 at ful stress
Chrech if you can get a better fit for GPU2.
drbo :thumbup: [MSIE_newline_end ]
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
dimanche 25 avril 2010, 12:41
You have to remove the block to see the engarving (if it is there). It is on the base which has contact to the card.
wholehog439
samedi 5 juin 2010, 04:03
What is the difference with the Rev.2 blocks?
thanx
lundi 7 juin 2010, 23:10
Rev. 2 has some small changes on the base to avoid contact problems with specific components of the card.
wholehog439
lundi 21 juin 2010, 07:59
So could having the rev.1 block cause any problems, I could not see any rev.2 engravings on my block.
thanx
