• 15.11.2026, 08:20
Finally available: poweradjust 2
jeudi 10 juin 2010, 00:02
It has taken a long time but finally it is here: the poweradjust 2
The poweradjust 2 is a controller which was optimized for the use with a Laing DDC pump but you can also use it for other things with a constant load of up to 25W at 12V. The maximum surge current can go up to 48W so you have enough reserves for the massive starting current that some pumps or fans generate. A freely configurable startboost allows you to make sure that for example a pump has enough time to spin-up before it is getting slowed down by the controller. That feature also works if the speed or flow rate signal gets interrupted.
Besides the already known connections like power output, its speed signal, USB, flow rate sensor and speed signal output this variant offers some new connections: an external temperature sensor can be connected and allows to monitor temperatures in the range of -40°C to +100°C. Two aquabus connections will allow full interaction with other upcoming devices in the future. You can be sure that the soft- and firmware will get some updates by time.
Instead of using manual control settings the ultra variant of the poweradjust 2 also offers a temperature-dependent control. It is designed very similar to the fan controller of the aquastream XT and allows a very detailed control over the power output. If you don't need that feature you can grab the standard variant of the poweradjust 2 which offers all functions of the ultra variant with the exception of the temperature-dependent control.
As you can already see on the photos the size of the passive cooling block is much bigger now to dissipate the heat which is generated by the voltage regulator. A two-stage overload protection will guard your poweradjust 2 against possible damages if the voltage regulator is getting too hot. Additional alarm settings for the temperature, flow rate and speed signal will give you full control.
The ultra variant will cost 39.90 EUR while the standard variant costs 34.90 EUR. With an upgrade key you can turn a standard controller into an ultra variant at any time.
A 5.25" bay cover for up to three poweradjust 2 will be available for 14.90 EUR.
The delivery will start next week.
A couple of photos of the controller:
An overview of the software:
5.25" bay cover for up to three poweradjust 2:
drbo
jeudi 17 juin 2010, 20:52
An absolute beauty! I also very much like the bay cover. But will the front plate also be available in black?
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
hobbes_dmS
jeudi 17 juin 2010, 21:04
it will.
question is: when? ;)
vinnybear
Aquacomputer poweradjust 2 USB Ultra availability ??
vendredi 29 juin 2012, 08:00
I have on back order at my usual water cooling supplier 2x Aquacomputer poweradjust 2 USB Ultra since 2 months now and they just keep shifting the delivery date forward every 2 weeks. It seems no one has this part in stock now.
Will you produce this again ?
vincent
germany
vendredi 29 juin 2012, 09:20
We would really like to produce this again but we are waiting for a delivery from a supplier since several weeks now. The poweradjust should be available again by mid July.
vinnybear
vendredi 29 juin 2012, 10:19
thanks for the speedy reply.
I look forward to the next few weeks and the good news then :)
vincent
