• 22.11.2026, 20:58
BudoBob
Difference between XT and HF?
samedi 7 août 2010, 15:25
Much time has been spent Googling but I have not been able to find an answer.
What is the difference between the Kryos XT and HF? Given the different metals used, is it purely cosmetic or is there a slight difference in performance?
Thanks.
samedi 7 août 2010, 22:49
The HF variant has a larger distance between the threads so you can use bigger connectors. If you take a closer look at both blocks you will notice that the outer side of the HF variant is slightly extended.
BudoBob
dimanche 8 août 2010, 02:06
Cheers Shoggy.
When you said "bigger connections", what realistically is the maximum size of the connections on the XT?
Thanks again.
dimanche 8 août 2010, 14:54
I don't know the exact distance at the moment but you can use Bitspower 16/1x connectors with it and they are already quite large.
BudoBob
dimanche 8 août 2010, 21:40
Thanks again Shoggy.
