• 23.11.2026, 00:17
crazy8s846
First time aquastream xt user, has a question
lundi 30 août 2010, 04:30
Ive got my pump in and its working great.
My question is, in aquasuite the pump in manual is maximum 80 Hz,
if i turn it up past 75.5 Hz it just resets over to 50 and goes back up to 75.6 then it resets over and over.
Why cant i go to the top maximum of 80 Hz with out it resetting like it does.
lundi 30 août 2010, 12:08
You won't be able to any higher since it seems that 75.5Hz is the maximum in your loop. The pump is able to detect if the rotor is running stable. At a specific fault tolerance of the sensor values it will stop and use a frequency slightly below the last frequency to ensure a proper operation.
crazy8s846
lundi 30 août 2010, 13:32
Thanks shoggy
