• 21.11.2026, 13:49
creekin
Faulty Temp Sensor
samedi 2 octobre 2010, 10:49
I have 3 AC inline inner/outer G 1/4 temperature sensors.
One of them reads 13c and the other 2 read 20c, in a cold loop.
I have emailed my retailer and AC and expect no problems getting a replacement.
Just wondering if anyone else has had this problem or if there are any software solutions.
Could is still be reliable with a temp offset setting?
samedi 2 octobre 2010, 14:29
You can't solve that via software. The sensor inside the connector is damaged. Very likely through a too high pressure. Even if you would add the missing 7°C by software you would still get wrong temperatures since the sensor does not work correctly at all - it might even stay at 13°C no matter what the real temperature is.
creekin
samedi 2 octobre 2010, 14:33
yeah i thought that would be the case.
I have sent you an email about it. (to info@)
creekin
dimanche 3 octobre 2010, 03:50
I haven't received a reply to my email yet.
My retailer suggested I contact you direct and that you (AC) would send me a replacement part.
Is this correct?
dimanche 3 octobre 2010, 11:04
We do not work at weekends so you will have to wait till tomorrow ;)
creekin
dimanche 3 octobre 2010, 16:48
Well i figured if its a weekend here, it must be a weekday there.
Because you are on the opposite side of the world...... ?( ;)
lundi 4 octobre 2010, 15:10
New sensor is on its way :)
Discussions similaires
