• 04.10.2026, 00:00
bmw81
Aquaduct 360 XT mark III question
lundi 8 novembre 2010, 09:59
Hi all,
I received my aquaduct, I will now ask whether it should be placed at the same height of the pc-tower or if I can put it over the pc-tower (about 1.5-2.0 m). Also I would kindly ask what is the maximum distance from the tower can be placed to not have problems with the pump and water circulation?
Best regards
Andrea Pedrotti
lundi 8 novembre 2010, 14:03
As height difference I would recommend to avoid distances larger 1m. It should still work but might decrease the performance.
The maximum distance is hard to answer since it depends a lot on the rest of the system. Around 3 meter should be no problem. Cold be even much longer but as said it depends on many things.
