• 13.11.2026, 09:47
gromax
Aquacomputer poweradjust 2 USB
samedi 4 décembre 2010, 21:00
Hi!
Im wondering if it is possible to connect one DDC pump and also one fan to a single poweradjust controller (or maybe even split a connection (if necessary) to use even more fans, and how will this then work in the software? Will i be able to contoll them separately?
Also im wondering if there will be any problem with running three poweradjust controllers, each running one Laing DDC (+ one fan per controller if possible) in combo with one Aquastream XT (used in a different loop for GPUs) trough the software? :crazy:
Weihnachts-Shoggy
samedi 4 décembre 2010, 21:05
The controller only has one output so you won't see any additional controlling options in the software when you split it. Of course you can use also other things together on one output as long as you are not exceeding the maximum available load.
Using a few controllers together is also no problem. Each device will get its own tab within the aquasuite.
Tomado
Two Poweradjust 2 and Laing D5
samedi 1 janvier 2011, 08:59
Hello.
My dream is to connect to the Aquaero Laing D5. :crazy:
I know, that it is impossible to make it directly. But is it possible to connection of two Poweradjust 2?
Whether it can work? Could they give in the sum 50 W in this case?
Ce message a été modifié 1 fois. Dernière modification effectuée par "Tomado" (2 janvier 2011, 20:52)
Weihnachts-Shoggy
lundi 3 janvier 2011, 10:34
No, that will not work. When you combine the devices you can not make sure that both use the same voltage output which would cause problems with potential equalization. It is very likely that one controller will die because of this and the other will just follow since it can not handle the load alone.
Tomado
lundi 3 janvier 2011, 19:58
Thank You very much for your reply!
