• 12.11.2026, 20:16
lagmo
Aquaduct XT 360 flowsensor malfunction
mardi 18 janvier 2011, 16:15
My Aquaduct 360 XT flowsensor appears to be dead, there's plenty of flow through the system, easily viewable, both through the top lid and the hoses inside the PC.
Which replacement part(s) will be needed to fix this?
I figure the fault could lie with the sensor itself, the cabling or the input port of the controller, but until I have some parts to experiment with, I'm unable to narrow it down further. :(
Hope you can help
mercredi 19 janvier 2011, 17:29
Might be some dirt inside the sensor chamber that is blocking the impeller.
I do not recommend to open the aquaduct yourself since it is complicated to get it leak-proof afterwards. Without knowing which parts are faulty it would be a game of luck to get the right parts.
Discussions similaires
