• 08.10.2026, 05:01
KWalter
Aquaero 4 and PWM fans
jeudi 10 février 2011, 17:32
Am I OK using four pin fans with the Aquero 4 or will they not regulate correctly?
I just bought a couple of XSilnce 1.08W fans and I've just noticed they are PWM controlled and have four pins on the connector
Thanks
Keith
vendredi 11 février 2011, 09:05
The aquaero has only one direct 4-pin connector for PWM fans. Of course you can still connect the other three to the aquaero but since the PWM pin is left out they will only be adjusted through the voltage (analog) which should also be better since you can control them freely in their full range. For the 4th connector you can select if it should work in PWM or analog mode.
KWalter
vendredi 11 février 2011, 15:47
Err - there's no 4 pin connector on my Aquero 4 - they're all 3 pin
Thought it best to use 3 pin fans in the end though
Thanks anyway
vendredi 11 février 2011, 16:21
Ahhh, sorry! I had the aquaero 5 in mind since almost all questions of the last days were about the new one :)
Of course you can still use them with the old aquaero. They will be regulated through the voltage in this case. Keep in mind that the maximum allowed load of each channel is 10W (15W with powerbooster) and the overall load of all channels combined should not exceed 30W (45W with powerbooster).
