• 17.11.2026, 10:55
prongATO
Question about Aquaero 5 and devices
jeudi 24 février 2011, 14:19
If I have an external temperature sensor connected to an Aquastream XT, will one aquabus connection from the pump to the Aquaero pass all the external temperature values?
Dr. Shoggy
jeudi 24 février 2011, 15:34
Yes, that is possible. When you connect an external sensor to the pump and select this sensor to be passed through aquabus, you can use it with the aquaero 5 as a normal sensor.
prongATO
vendredi 25 février 2011, 05:15
Thanks for the quick response Shoggy. I'm in the process of going all Aqua Computer on my rebuild :) (pump, flow sensor and controller)
