• 22.11.2026, 23:00
silkeslips
Aquaduct 360 fan malfunction
lundi 28 février 2011, 10:59
I have a broken fan in my Aquaduct 360. Can the fans be replaced without opening the parts that contain water? If it can, do you have any recomandations for what type of fan i should replace it with?
Dr. Shoggy
lundi 28 février 2011, 16:55
Unfortunately there is no way to exchange the fan without opening the device. Normally you would remove the top of the device, pull out the fan cover and exchange the fan. All in all it is no big deal but getting it back to work without leaks is pretty complicated, especially if your device is older. In each side profile is a tube which normally will not fit perfectly again when you open the device once. It is high recommend to exchange them too.
Discussions similaires
