• 22.11.2026, 23:28
rab8772
Red light on aquastream xt ultra
mercredi 20 avril 2011, 00:42
I just finished putting my water cooling loop back together an now the pump will not work. I have tried using a jumper to reset to factory settings but its does not help. The pump does not seem to move or make a sound. When I plug the molex into the pump the red light comes on then goes off for a second then comes back on and stays on. It worked last week when I was testing the loop when I plugged the molex into the pump now it does not. I read the manual an similar posts but nothing has worked. Any help would be appreciated.
Ce message a été modifié 1 fois. Dernière modification effectuée par "rab8772" (20 avril 2011, 04:08)
mercredi 20 avril 2011, 12:31
A constant red LED means that the controller is defective. In this case you should send in the pump or only the controller.
rab8772
jeudi 21 avril 2011, 01:23
I removed the back cover on the aquastream. So to complete the controller removal just de-solder the wires from the controller board? What the repair/replacement costs including shipping from the US to Aqua Computer? What address should the controller be sent?
Thanks for the help.
Ce message a été modifié 1 fois. Dernière modification effectuée par "rab8772" (21 avril 2011, 04:28)
jeudi 21 avril 2011, 11:17
You only have to remove the two wires at the bottom of the controller. I recommend to send the controller in a padded envelope to save shipping costs.
You can send it back to:
Aqua Computer
Gelliehaeuser Str. 1
37130 Gleichen
GERMANY
Please include a short description of the problem and if possible a copy of the invoice. If the problem is covered by warranty you don't have to pay anything for the repair and shipping costs back to you. Otherwise the costs will be somewhere around 15,00 EUR.
Discussions similaires
