• 26.11.2026, 11:53
pleytos
Aquastream XT - Frei konfigurierbare Kalibierkurve??
vendredi 29 avril 2011, 23:46
Hello,
I've got one small question, I want to buy a pump.
There's only one thing I don't understand, what can you do with "frei konfigurierbare kalibierkurve"?
Thanks
http://shop.aquacomputer.de/product_info.php?language=en&products_id=1299
samedi 30 avril 2011, 00:29
You can change the temperature curve of the three temperature sensors (water, external and electronics).
The controller reads a so called ADC value which gets converted to a temperature by using the mentioned curve. Of course the sensors have a standard curve but you can adjust it to your needs. For example you would see that the temperature between a range of 30 to 40°C is read out to high you can fix only this area to get a more accurate measuring.
pleytos
samedi 30 avril 2011, 20:15
Thanks! Perfect explanation.
