• 20.11.2026, 03:18
rizosha
Aquastream capability question and advance of my RL loop
jeudi 12 mai 2011, 04:08
Hi all,
I would like to acquire some aqua-computer products. My system has already a RL solution with the following components:
i7 2600K with Apogee XTL water-block
2 x EVGA GTX 580 FTW Hydro Cooper 2
1x MCR220-Drive radiator with integrated MCP35X pump and reservoir
I want to change radiator for a bigger one (it will be out of the box, ie external radiator), thinking in a 4x120 or even 9x120 such as:
Phobya Xtreme QUAD 480 Radiator (4x120mm). Pressure: 2 bar
Phobya Xtreme NOVA 1080 (9x120mm). Pressure: 2 bar
I'm going to overclock my system (not extreme overclocking) and silent is important to me. So my questions are:
Can the Aquastream XT USB pump operates good with this loop? Will it be able to deal with the total pressure of this loop or should I choose another pump?
Are the radiators above suitable for my system or someone recommend to me another ones?
Thanks in advance and sorry all for my bad English!
jeudi 12 mai 2011, 10:02
That will be no problem for the pump.
Discussions similaires
