• 09.10.2026, 05:28
tnc99
Aquasuite 2012 BETA 2 Not working
mardi 24 mai 2011, 16:06
Using win 7 x64, did try x64 x86, running as admin. i cannot start any of them.
Beta 1 working ok.
"Disable A/V" What does it mean?
Peter
I7 2600K
6990+6970 Watercooled EK-Plexi Crossfire
Gigabyte GA-P67A-UD7
Coolermaster Silent Pro Gold 1200W
Corsair Obsidian 800D
2 x Crusial C300 Raid 0
Corsair vangance 2x4G
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
Phatboy69
mardi 24 mai 2011, 16:14
Installed no problem on my Win 7 64bit Ultimate SP1 over the top of beta 1. Make sure you have shut it down first of course..
A/V = antivirus
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
tnc99
mardi 24 mai 2011, 17:26
Now i even cannot run the beta 1, nothing happens
Still same fault with beta 2, did try to disable antivirus, and reboot before and after
Thanks!
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
mpolter
mardi 24 mai 2011, 18:23
beta2 won't start. Here is the error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: aquasuite.exe
Application Version: 1.0.0.0
Application Timestamp: 4ddb8f89
Fault Module Name: clr.dll
Fault Module Version: 4.0.30319.225
Fault Module Timestamp: 4d5367b6
Exception Code: c0000005
Exception Offset: 00000000006133e1
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 98a0
Additional Information 2: 98a0dc6a3196b6d2595be664d64dd287
Additional Information 3: 989f
Additional Information 4: 989f47bce12f4f3be563f0e265f6e069
--MikeP
tnc99
mardi 24 mai 2011, 18:27
I resat the aquareo to fabric setting, shutting down computer, took power off for 5 minutes.
Run repair of .net 4
Still no luck ;(
Will run some dirt 3, hope you guys find some solutions
Thanks!!!!
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
Paradoxxx
mardi 24 mai 2011, 23:00
Having the same problem.
Reinstalled a few times and ran as administrator all without success. I'm using the x64 Variant.
drbo
mercredi 25 mai 2011, 01:10
Same here, only crashes. Back to Beta1
drbo 8)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
hrmes
mercredi 25 mai 2011, 08:58
Same problem here with Win 7 x64. Aquasuite 2012 beta 2 won't start at all. Haven't tried beta 1.
Phatboy69
mercredi 25 mai 2011, 09:39
Check your MS .net 4 framework is fully up to date.
If you dont have it installed get it here> http://msdn.microsoft.com/en-us/netframework/aa569263
Ce message a été modifié 1 fois. Dernière modification effectuée par "Phatboy69" (25 mai 2011, 09:42)
tnc99
mercredi 25 mai 2011, 10:49
I made a repair of .net 4 without luck ;(
I7 2600K
Corsair H70
Aquastream XT Ultra
3x120 1x120 rads.
EK-Bay res.
Aquaero XT
Eyefinity 3x24"
aioneru
mercredi 25 mai 2011, 11:37
Windows 7 32-bit SP1. Disabled antivirus, started as administrator, repaird and even uninstalled and reinstalled .NET 4 and still no luck. Same as with beta 1. It starts, appears on the process list, uses CPU for a second or two and does nothing else. Tried killing the process and starting it again and again and again, and actually for about 200 restarts I was able to run it correctly two times. Once I used it to update firmware, and the second time I was able to synchronize the time and date. Now that's something. Didn't even try to play with anything else since even starting this thing takes a lot of luck.
I belive that the faulty part is actually using the .NET environment. We have been trying to port one of our software to it once, but with so many versions, configurations, security updates changing behaviour we gave up and back to native MFC application. Same as with installation file. We used one based on the Windows Installer, but after many complains and problems of unknown source we've switched to native Windows application (Inno Setup) and since then there was no even one problem reported with the installer. Of course at this point there's no way you would stop using .NET framework, but at least add some serious logging and client side debugging procedures (Eureka Log could be a nice part of it), otherwise you'll never start working on the real features and will end up with half of users not even able to run it for unknown reason.
Phatboy69
vendredi 27 mai 2011, 10:07
Another possible fix for you guys. I just plugged my iphone in this afternoon and Aquasuite crashed straight away and then 2 consecutive times it crashed trying to restart, only the 3rd time was it successful in restarting.
Try removing all un-necessary USB devices, I have seen USB issues like this between devices before so worth a shot.
Also try moving the A5 to a different USB port and doing a device reset on it.
Paradoxxx
vendredi 27 mai 2011, 16:03
My Debug info is as follows
System.Configuration.ConfigurationErrorsException was unhandled
Message=Configuration system failed to initialize
Source=System.Configuration
BareMessage=Configuration system failed to initialize
Line=0
StackTrace:
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
at System.Data.Common.DbProviderFactories.Initialize()
at System.Data.EntityClient.EntityConnection.GetFactory(String providerString)
at System.Data.EntityClient.EntityConnection.ChangeConnectionString(String newConnectionString)
at Database.DatabaseConnection.getConnection(String modelName)
at Datahandling.UserpageList..ctor()
at AquaComputer.Aquasuite.App.OnStartup(StartupEventArgs e)
at System.Windows.Application.<.ctor>b__1(Object unused)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.WrappedInvoke(Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run()
at AquaComputer.Aquasuite.App.Main()
InnerException: System.Configuration.ConfigurationErrorsException
Message=Sections must only appear once per config file. See the help topic <location> for exceptions. (C:\Program Files\Aqua Computer\aquasuite 2012\aquasuite.exe.Config line 19)
BareMessage=Sections must only appear once per config file. See the help topic <location> for exceptions.
Filename=C:\Program Files\Aqua Computer\aquasuite 2012\aquasuite.exe.Config
Line=19
StackTrace:
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.ClientConfigurationSystem.EnsureInit(String configKey)
InnerException:
vendredi 27 mai 2011, 17:17
Phatboy69
vendredi 27 mai 2011, 17:20
Looks like a config file issue. Maybe uninstall both versions of it and manually delete any files left in the installation directory. Then reinstall beta 2.
I noticed there were 2 versions of aquasuite 2012 in my control panel "Control Panel\Programs\Programs and Features" where you uninstall programs from. Didnt seem to effect my system though for some reason.
Paradoxxx
vendredi 27 mai 2011, 17:33
Didn't work...
I was able to get Beta 1 working again after manually deleting the Aquacomputer Folders in Program Files
Phatboy69
samedi 28 mai 2011, 10:16
Found this in the German forum maybe help someone here.
The following steps were performed:
1. Uninstallation. NET 4 Extended
2. Uninstallation. NET 4 Client
3. Registry cleaner running (in my case tuneup 1 click maintenance)
4. Computer restarts
5. posted the link to Sebastian. NET 4 charged
6. . NET 4 installed -> this alone has not helped Aqua Suite up and running
7. loaded via Windows Update two security updates for. NET 4 (one for client and one for the extended version KB2416472/KB244670 , Right after successful installation of these updates I could run the Aqua Suite 2012
aioneru
samedi 28 mai 2011, 17:58
Sebastian wrote on the German board that everything needed to run on the clean Windows 7 machine is the installation of the .NET Framework 4. But I tested this, and this doesn't seems to be the case. I have a Windows 7 (and actually every other Windows version out there) clean installation under VMware for my software developing tests: not even a single default option changed, installed SP1, added .NET 4, installed beta 2 of Aquasuite and it does the same thing as on my real machine: it starts but it doesn't appears nor does anything else.
As I am eager to get this working I also tried Phatboy69's method under virtual machine, since I don't have the acces to the Internet under it, I've downloaded and installed manually KB2416472. The other one can't be installed since it's for .NET 3. Also tried this on my real machine, and Windows Update didn't find any updates for .NET 4 to be installed...
samedi 28 mai 2011, 18:49
Just wait for the next Beta Version (10 - 14 days). I have the same problem on my private system so at least we have a PC to analyze these problems in detail.
gahlaktus
samedi 28 mai 2011, 22:50
Phatboy's solution worked for me!!!
