• 23.11.2026, 01:02
codeman
Aquaero 5 - Tach plug
lundi 6 juin 2011, 18:42
Hi all,
I am trying to figure out how to use the 3 pin plug labeled 'Tacho' on the far right of the Aquaero 5 - I can't find anything in the menus that will allow me to display the output of this tach plug; I've got my pump tach wire plugged into this and all the other 4 fan channels used... would love to see the output and not have that Tach. plug wasted. Is this plug not activated or am I just not seeing where the settings for it are?
Thanks!
Phatboy69
RE: Aquaero 5 - Tach plug
mardi 7 juin 2011, 13:45
Hi all,
Thanks!
This is used to send a tach signal to a motherboard fan header, I dont think the feature is activated yet. Its not a reciever port its a sender port so you can trigger an event via CPU bios or software such as shutdown.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
codeman
mardi 7 juin 2011, 19:36
Ah really? Cool feature, though I was hoping it was another tach header - but then, that'd be a waste. Makes sense now - thank you for the reply :)
