• 06.10.2026, 08:08
cristian.ticu
Aquasuite 4.72 flow sensor question
dimanche 12 juin 2011, 18:53
Hi,i have an aquaero 4.00 unit hooked umong others to an aquacomputer high flow sensor.I run a loop with two laing D5 pumps,and the flow rate is about 430l/h,with the sensor calibrated at 169 impulses.all ok....but in aquasuite the graphic bar measuring the flow is black,not blue or red.is this something iI should be worried about? what is the meaning of the black bar in aquasuite?
vendredi 17 juin 2011, 10:02
Are you able to test that on another PC? So far I guess that might be some visual glitch caused by something else.
Is that bar graph showing a correct value but only in black or is the whole area black so you can not see the current value?
cristian.ticu
samedi 18 juin 2011, 15:31
no,only the bar that is supposed to be blue.
http://imageshack.us/photo/my-images/864/unledpus.jpg/
no matter.it all works flawlessly.and i intend to replace my last aquaero 4 with the aquaero 5,since there will be no support for it in aquasuite 2012.aquaero 5 kicks ass.
