• 03.10.2026, 02:13
DMW5678
Discovered two small issues with Aquero 5 -- looking for a solution
jeudi 7 juillet 2011, 17:03
Two features no longer work. First I have the XT model
1. From the aquasuite 2010 Beta 4 software I changed the user interface --> Temperature unit --> to Fahrenheight and it will not allow me to change it back to Celsius .. It wil display Celsius in the drop down but not change the display within the software. The hardware display does seem to register the change.
2. I adjusted the F3 key down to 0 sensitivity from the hardware unit and now I can no longer gain entry on the menu to adjust any of the sensitivity levels for all keys. The remote control does not assist here either. I can navigete to the menu, nut not go into the panle to adjust the levels. This is very strange. ?(
I was thinking I could update/reapply the firmware to reset everything. Currently I'm on firmware 1012..
Any help with this matter would be greatly appreciated. :thumbup:
XNine
jeudi 7 juillet 2011, 17:18
I think your best bet it to get it to reset back to factory defaults....
Phos
vendredi 8 juillet 2011, 09:01
I have the pro, but can't you change this under User Interface - Key Settings in Aquasuite?
