• 29.09.2026, 12:02
pphx459
Aquaero 2012 Does Not Start
lundi 11 juillet 2011, 11:54
When I run AQ2012 beta 4, the app launches but does not open up the interface. I can see the app in the task manager using cpu for about couple seconds. Then it just goes to 0 cpu usage and doesn't ever pull up the interface.
I've tried repairing .Net Framework 4 and even reinstalling it. Still the same problem. Also, tried running as admin, doesn't help either. Any ideas?
FutureCorp
lundi 11 juillet 2011, 14:16
I had the same problem using a aquaero 5.
Do you use the same device? or you have a different setup?
If you have the same, try the following.
Instal the software before, plugging in the internal USB cable. Connect the USB after instalation.
I had a similair problem. I did install before inserting the usb. The program did not start, than plugged in the usb and than it did. After this i was able to start the program with or without the internal usb connected.
Also pay attention to connecting the usb, properly its only a "half" connector which theoretically could be placed 3 times wrong and 1 times right.
Hope it helps
pphx459
mardi 12 juillet 2011, 07:52
I have the AQ5. Reinstalled Windows 7 a few days ago all was working well. Then all of a sudden it wouldn't load up anymore.
I'll give this a try and report back. Thanks for the advice.
pphx459
mardi 12 juillet 2011, 09:07
Finally got it sorted out, phew :)
Looks like it wasn't able to display because of dual monitors. Had to turn off 1 monitor, run the app, and then maximize it on the other monitor. I wasn't able to maximize on the first monitor no matter what until I turned it off and the task bar moved to the 2nd.
FutureCorp
mardi 12 juillet 2011, 17:43
Ah that's a classic 2.
well congrats.
