• 02.10.2026, 20:09
Nilil Simile
Laing DDC
lundi 25 juillet 2011, 09:22
What connector do you hook to on the aquaero 5 to run a laing DDC pump?
turtletrax
mercredi 27 juillet 2011, 00:26
If it is one of the models that support PWM you would use the fourth channel, if not any of them will do. Just remember channels 1 and 2 are thermally connected as well as 3 and 4. So if you have decent loads on channles 1 and 2, put the pump as far away (ie: channel 4) and vice versa.
jeudi 28 juillet 2011, 12:29
For a normal pump with analog voltage control you would use this cable:
http://shop.aquacomputer.de/product_info…roducts_id=1622
Discussions similaires
