• 20.11.2026, 22:43
franknitty69
Aquaero 5 Waterblock Fittings
vendredi 9 septembre 2011, 00:00
Hello,
Does anybody know if the Aquaero 5 Waterblock will fit 2 compression fittings? I saw an install where the person had to use one 45 degree rotary and a standard compression.
This fitting from Bitspower looks like it sits high enough above the waterblock screws.
http://www.frozencpu.com/products/11110/…l=c409s1033b145
Will two of these fit the waterblock?
XNine
vendredi 9 septembre 2011, 05:04
The typical BP compressions did not fit mine. The were too thick/ports too close. I suppose you could try, but to my knowledge, compressions won't work since the ports are too close.
franknitty69
vendredi 9 septembre 2011, 05:08
what kind of fittings did you use for yours?
Namron
vendredi 9 septembre 2011, 09:41
I used two compression on both of my Aquaero's, one 45° & one straight no worries :)
N.
Ce message a été modifié 2 fois. Dernière modification effectuée par "Namron" (9 septembre 2011, 09:54)
franknitty69
vendredi 9 septembre 2011, 18:46
N.
your post was the one i was referring to lol. anyways, i'm going to give the bitspower rotary compression and the dual rotary 45 degree compression a try. i'll post pics when i get them.
Namron
samedi 10 septembre 2011, 21:26
Ahh Right :)..... I should have mentioned in my last post the two straight compressions wouldn't fit, I tried with Bitspower & standard straights & niether had enough room, Hence why I went for 1 x 45° & one striaght on the post you first saw it in.
On my new build I have two 45° fittings because I needed the tubing to go a certain direction. So either 1 x 45° & one straight will have enough room or 2 x 45° fit OK as well :)
N.
