• 25.11.2026, 05:04
dbdecker
My PC design, suggestions please
samedi 22 octobre 2011, 01:51
I have been researching products for a while now and want to ask for advice to achieve the following.
Control 5 fans on a radiator (all at the same time) and 4 system fans (all at the same time)
Rad fans are the enermax Magma's, 120mm no LED
Sys fans are 120mm with LEDs
I want to ues the aquaero 5 XT product to control the system. (ordered and on its way)
Can you provide any advice on this set up?
Which product configuration with the aquaero would work?
Can i put all the fans together on one of the outputs of the Aquaero?
I don't intend on running pump control or measuring flow control just yet. That can be later when I upgrade to ivy bridge system. :evil:
Regards,
DBDecker
Ce message a été modifié 2 fois. Dernière modification effectuée par "dbdecker" (22 octobre 2011, 19:13)
dbdecker
dimanche 23 octobre 2011, 04:41
Seems its worth just grabbin some poweradjust 2's and be done with it properly.
Ce message a été modifié 2 fois. Dernière modification effectuée par "dbdecker" (23 octobre 2011, 07:07)
mercredi 26 octobre 2011, 14:55
So 9 fans in total? That will be no problem for the aquaero as long as these fans do not draw a massive amount of power.
You can use y-adapter to group them.
dbdecker
mercredi 26 octobre 2011, 23:19
Thanks Shoggy!
I'd been searching the forum and found similar requests.
Might be worth putting up a sticky.
Since the original post i've changed my case which actually means less fans. I've bought the waterblock from my aquaero too to make sure it stays a nice temp.
thanks again
