• 12.11.2026, 20:12
JB3
Aqua Computer Control System Questions
jeudi 8 décembre 2011, 03:00
I have an Aquero 5XT, (2) Aquastream Ultra XT pumps, (2) AC High Flow Sensors, and currently in shipment (6) Poweradjust 2’s. I have a few questions about hooking them all up.
1. I will have (2) AC PA2 bay mounts for the (6) PA2’s. Are there Aquabus cables sold that are the correct length to jump from PA2 to PA2 to PA2 when the triple PA2 bay mount is used?
2. Is there a molex cable made to connect (3) PA2’s in an AC PA2 triple bay mount?
3. Can (3) PA2’s be connected to one molex cable?
4. If the Aquero 5 XT, Aquastream pumps, and PA2’s are all connected together on the Aquabus will connecting temperature sensors and flow sensors into the pumps work or do they have to be connected to the Aquero 5 XT?
5. I am using Windows 7. Where do I find the program I should use with my Aquero and what is the file name I should download?
Pilo
dimanche 11 décembre 2011, 16:49
I only have an answer to point 5. Look here for aquasuite 2012 BETA 9 for 64/32-Bit Systems. This is the right one for the Aquaero 5-Series.
mardi 13 décembre 2011, 13:02
1.) We have no special aquabus cables. They are 50cm in length.
2.) No special cable available. Just use y-adapters for example-
3.) Might depend on your PSU and the load that you want to connect but it should normally work.
4.) You can not access the flow rate from the pump via aquabus. It is only possible to access one of the temperature sensors (must be configured at first via USB).
Discussions similaires
