• 22.11.2026, 21:34
Some_Nob
Flow Sensor Calibration Value
samedi 25 février 2012, 18:50
Hello, can anyone tell me Calibration represents...
I have a Koolance FM17 and a RPM adaptor, basically the adaptor is putting out a RPM signal equal to mL/min.
So if its signal is 2000rpm it means 2L/min how to calibrate that into the Aquaero 5 so it represents correctly.
Ive put in 1000 guessing thats what it would mean.. but like a confirmation.
Cheers.
SteinerKD
dimanche 26 février 2012, 12:18
In this thread someone is using FM17 with Aquaero and suggest calibration set to 169, he doesn't say what tubing he uses though (I've seen that number for the plug n cool stuff). The calibration is dependent on the tubing though and in a review (of ACs "high flow" sensor) I read 158 was suggested (I think that was for 10-11 ID tubing).
Nihil Simile
dimanche 26 février 2012, 18:44
I was told by support when using the Aquacomputer High Flow like the one that is being tested, you should choose the High Flow option in the Aquareo calibration menu.
