• 20.11.2026, 00:27
Rjrolyn
Aquaero 5 XT Still active in Background after PC is shut off.
lundi 12 mars 2012, 07:39
Aquaero 5 XT Still active in Background after PC is shut off.and no Aquacomputer welcome screen when powered on just picks up last activity while PC is off . any suggestions?
Ce message a été modifié 2 fois. Dernière modification effectuée par "Rjrolyn" (13 mars 2012, 01:16)
SoMBrA
mercredi 14 mars 2012, 17:11
I guess it's because of the power standby connection?
If you just feed the Aquaero via MOLEX and you shut down the system it should turn off (can't tell you 100% sure since I'm waiting the AQ5 myself...)
Unomel;odica
jeudi 15 mars 2012, 00:10
make sure the motherboard usb connection is assigned to the correct pins on the acquero
That should enable the correct turn on and off procedure.... :thumbup:
Uno
franknitty69
mardi 27 mars 2012, 04:01
this is standard operating procedure. the aq5 remains on when the pc is off if the motherboard is still receiving power.
