• 29.11.2026, 23:14
Phatboy69
A5 XT Media Player control
lundi 25 juin 2012, 12:06
Hi there,
I have just tried to use the remote to control media player and it doesnt seem to work.
I can control the mouse and use the remotes keyboard but when I change to media keys it doesnt do anything.
It used to work, but I havent it used for ages...
Is there any drivers or settings that need to be installed or changed to make media keys work in windows media player or itunes?
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
lundi 25 juin 2012, 16:54
The key assignment for these keys is done by Windows so maybe it has been changed in some way. That can happen when you install several different multimedia players. I recommend to have a look at Google with keywords like media key assignment etc.
Phatboy69
mardi 26 juin 2012, 03:51
Thanks Shoggy I looked into that but it was a dead end.
I downgraded to AS Beta 10 and Firmware 1019 and the media keys are working again.
Perhaps its a 1024 firmware or AS B14 issue?
Confirmed by going back to FW 1024 and AS B14 the media keys stop functioning again.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Phatboy69" (26 juin 2012, 04:00)
mardi 26 juin 2012, 09:17
We will have a look into that for the next firmware.
