• 20.11.2026, 01:28
Psychor
AQ5 Pro (1024; Beta 14) - alarms don't work?
mardi 26 juin 2012, 03:56
I've set alarms (e.g., buzzer & shutdown) to go off when my flow falls below a certain point. You can see the alarms are set but once the flow drops low enough none of the alarms activate. Please advise.
Thank you.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Psychor" (26 juin 2012, 04:12)
Psychor
mardi 26 juin 2012, 04:12
I did some further testing and instead of trying to trigger "Warning" and "Alarm" based on flow I tried to trigger them based on temperature. The temperature worked. Clearly something is not working properly with the flow "Alarm Configuration."
mardi 26 juin 2012, 09:17
Very strange, we will have a look into that for the next firmware version.
Psychor
mercredi 27 juin 2012, 22:05
Thanks Shoggy. This is one of the major reasons I bought your flow sensor - so I could trigger a shutdown.
Let me know if you guys need me to test anything.
jeudi 28 juin 2012, 11:43
Maybe an idea: it might be possible that one of the values is interpreted in liter. Could you test if it works when you set the unit to liter.
Of course we will have a look into that but it is our first idea at the moment.
adolfotregosa
jeudi 28 juin 2012, 13:28
mine is working in liters and the alarm works , so Shoggy suggestion should work, !! BUT !! you have to set the liter limits on the aquero itself since the aquasuite max value is only 120... ;( :cursing: X(
Shoggy , another bug to be fixed on the next aquasuite :D
jeudi 28 juin 2012, 16:37
It's on the list.
Psychor
vendredi 29 juin 2012, 06:27
It's on the list.
Great. Thanks.
ugapug
mardi 3 juillet 2012, 03:56
Any idea when the next version is coming out?
mercredi 4 juillet 2012, 08:54
Mid July
ugapug
jeudi 5 juillet 2012, 04:53
Cool, thanks.
cc01
Same problem
dimanche 8 juillet 2012, 13:45
I have the same problem but my sensor is set to litres. Cannot set an alarm with the option "flow falls below limit". If I set it to "flow exceeds limit", it triggers an alarm irrespective of the value I put in for the limit. Does the flow direction through the sensor have anything to do with it? If the 3pin output generates a signal according to the impeller spinning in one direction, would it change the signal and thereby confuse the aquaero if it was spinning in the opposite direction?
lundi 9 juillet 2012, 13:22
We already found a bug with the different measurement units so this will be also fixed in the next version.
