• 13.11.2026, 18:10
hrmes
Program to set time in Aquaero 5
jeudi 12 juillet 2012, 10:14
In order for Aquaero 5 to display the correct time and date I have to run the Aquasuite at least once a day.
I could also run Aquasuite at startup with Windows but I don't want to have it running just to set the time.
A better solution would be a small program that could be run at startup that would do just that, read the time and date from Windows and send it to Aquaero 5 and then exit.
Do you think your team could do that ?
jeudi 12 juillet 2012, 10:23
in the aquasuite programm folder is a small tool: "aquacomputerTimeSync.exe" you can add this with a shortcut to your autostart folder.
hrmes
jeudi 12 juillet 2012, 10:44
That worked great! Thanks very much!
