• 29.11.2026, 22:53
gobase2008
Problem with sensors in Aquasuite 2012 Beta 15
lundi 30 juillet 2012, 03:13
I finally got my Aquaero last week, so I connected it and downloaded the latest Aquasuite.
After a few restarts of the software I noticed that the titles for most of the sensors on the overview pages has strange characters.
See images attached.
Also, the same is happening under "Sensors" config page:
I realize now that my setting for "Controller" when I use 'curve' are not moving the fans.
They remain in "zero" speed,,, and they were working before the dummy characters started to appear.
I had to change the controller action for "Preset Value" so I least I have fans working.
If the 'curve controller' setting doesnt work, it defeats the whole point of having an Aquaero,, which is basically a Fan Controller in steroids.
Has anybody experiences something like that?
Im using Flow sensor, one physical temp sensor on the Aquaero, 3 software temp sensors (provided by Open Hardware Monitor) and 1 virtual (average from the three Software Temp sensors).
Thanks
Manny
gobase2008 a envoyé les images :
lundi 30 juillet 2012, 08:20
Reset all settings. Do not use a old profile.
gobase2008
lundi 30 juillet 2012, 17:09
Hello Sebastian
What exactly do you mean by "Reset All Settings"?
(Factory Defaults?)
I uninstalled the software and reinstalled,, same problem.
I did export and import a profile,, for test, and this happen after,, but not immediately.
What do you mean with "old profile"? (From and Old Aquasuite software? because this is the only version I ever installed,, Beta 15)
Thanks!!
Manny
917K
mardi 31 juillet 2012, 12:03
Hello Sebastian
(Factory Defaults?)
Thanks!!
Manny
I had the same problem, and I've solved restoring the factory default.
which software you use to export the software sensor?
gobase2008
mardi 31 juillet 2012, 15:32
Yes,, I figured that Sebastian meant that.
I restored defaults and now the dummy characters disappeared.
Im using Open Hardware Monitor by the way.
Thanks
