• 03.07.2026, 09:40
Psychor
Aquasuite 2012 BETA 16 bug - flow
mardi 14 août 2012, 00:35
I have my flow meter set to "gal/h" in AS 2012 and in AS it shows up in "gal/h." However, the AQ 5 Pro still show "l/h" on the LCD.
cc01
mardi 14 août 2012, 05:02
What is your actual question?
It's probably a bug in the firmware. Something for the next update ...
Psychor
mardi 14 août 2012, 05:59
I don't have a question. I was bringing a possible bug to the attention of AC so that they can fix.
cc01
mardi 14 août 2012, 09:02
OK. Good.
LarryWill729
mardi 14 août 2012, 18:33
I have frequently had similar display unit discrepancies. In the AS 2012, there is a section for Aquero 5 user interface where units are selected, Also, at the bottom, there is a section Aquasuite were display units are selected. Both section have to match, and you have to click the "floppy" icon next to Aquero 5 to save it to the Aquero 5 itself.
Hope this helps.
AMD FX-8150 OctoCore O.C. 18% to 4.2 GHz on ASUS M5A99X EVO with 16 GB Corsair Dominator W. C. RAM, 2 nVIDIA Geforce 560TI W.C. in SLI, six Western Digital drives for a total of 4.07 TBytes, AquaComputer Aquero 5 Pro, AquaComputer D5 pump, Multiswitch USB, tubemeter and Kyros CPU block. Two coolant loops,CPU & SLI, MB, RAM and AQ5, with two flow meters. Running Windows 7 Professional 64, and using Open Hardware Monitor v0.5.1Beta Aquasuite B16 hardware temps.
Psychor
mercredi 15 août 2012, 01:30
Hope this helps.
Good call. Problem solved. :thumbup:
LarryWill729
mercredi 15 août 2012, 09:12
Go figure! I have tried several "Answers" posted to this and other Forums, and very few of them actually solved my problem, but they usually provided the correct "Clue Stick upside the Head" for me to figure it out myself.
I just LOVE Beta Testing! :rolleyes:
