• 28.11.2026, 04:43
jeudi 6 septembre 2012, 11:49
When the multiswitch is connected to the aquaero 5 via auabus, then jumper 5 must be set and USB must be disconnected. The multiswitch will not be visible as a new device within the aquaero or the software. You will just have some new outputs (the channels and relay) in the list to chose from. While in aquabus mode the multiswitch can not use the PWM control to dim the channels so you can only switch them on and off.
Spooner
lundi 22 octobre 2012, 18:57
Hi all,
Its been a while since i've had to come here as everything has been working just fine.
However, I recently rebuilt my machine replacing my motherboard for an Asus Max 5, CPU, and GFX cards and went through putting everything back together, reinstalling Windows, and of course Aquasuite.
Couple of things:
After flashing the fw to 1025, the over sensitive touch screen is back, and I cannot control the Aquaero with the remote control unless the buttons are disabled, it keeps displaying a page that doesnt have any info on it.
I setup my overview page, and now everytime I load the software, all the titles for all the sensors are just blanks. On the Aquaero itself though the labels and pages are all as I expect and working fine.
Water Cooling: Aquaero 5XT /w 1x High Flow Sensor, 2x Inline Temp Sensors & Waterblock. Lamptron Touch x6 Fan Controller, EK CSQ Supremacy CPU Block, 2x EK CSQ GTX680+ VGA Blocks, 1x 120mm, 1x 360mm, & 1x 480mm EK Coolstream Radiators. 22x 120mm Coolermaster Fans.
Hardware: Corsair AX1200PSU, Asus Maximus V Extreme, i7 3770k, 16GB Corsair Vengeance DDR3 1866, 2x Palit Jetstream 4GB GTX680, 1x 120GB & 3x 240GB OCZ Agility 3, Asus DVDRW, 3x Asus VE278Q LED. Mountain Mods Ascension Alloy Chassis.
mardi 23 octobre 2012, 09:16
Please try a reset: power off the device, place a jumper on temperature sensor port 8, power on the device, wait a short moment and power it off again + remove the jumper.
