• 29.11.2026, 08:44
BorisTheSpider
Load profile 1 -> Load profile 4
dimanche 30 septembre 2012, 11:21
I see in the alarm actions in aquasuite, there are options for "Load profile 1" through to "Load profile 4"
But I can't see anywhere that I set what profiles to use - I can import and export profiles through the system tab, but that only lets me load or save what is active now. I want to aquaero to have more than one profile loaded on-board, and to be able to switch between them as a result of an alarm condition.
How do I do this?
Ps. I have just done some googling and seen a set of screenshots where someone did this on the aquaero itself, but I have an LT so can only work through aquasuite. Is it possible to do this through aquasuite? If not please can the devs add it in a future release so the LT can use profiles.
Ce message a été modifié 1 fois. Dernière modification effectuée par "BorisTheSpider" (30 septembre 2012, 11:33)
vendredi 5 octobre 2012, 09:07
At the moment that is not possible with the LT variant. Maybe this feature will be integrated to the aquasuite in the future.
Right now you can only store and load a profile manually through aquasuite.
BorisTheSpider
vendredi 5 octobre 2012, 14:35
Thanks for the reply Shoggy. It would be great if you can work this into a future release.
balizeiro
samedi 4 mai 2013, 01:08
Any new information regarding this matter?
EDIT: Because what I need is to change the speed of my pump if the flow drops below a certain value
Ce message a été modifié 1 fois. Dernière modification effectuée par "balizeiro" (4 mai 2013, 15:01)
