• 11.11.2026, 18:11
pegleg
how do i get my ac flow sensor working
mardi 9 octobre 2012, 20:28
how do u hook the ac flow sensor to the aquastream xt pump.i have it hooked up to my internal usb motherboard how do i get it working this is my pump(http://shop.aquacomputer.de/product_info…roducts_id=1301 this is the ac flow meter or sensor.( http://shop.aquacomputer.de/advanced_sea…s=53129&x=0&y=0how do i get this to work.thanks to all that help.
pegleg a envoyé l’image suivante :
Ce message a été modifié 2 fois. Dernière modification effectuée par "pegleg" (9 octobre 2012, 20:51)
mercredi 10 octobre 2012, 10:01
In aquasuite 4.72 go into the tab pump and flow rate settings. At the end of this screen you will find an option to select how the connector on the pump should work: select flow sensor and set the calibration value to 169.
Go in the menu bar to aquastream XT -> save settings in device. Shut down the PC (must be off) and turn it on again. The flow sensor should work now.
mercredi 10 octobre 2012, 11:25
You Can't hook it, it shut working on USB and aquasuite 2012
@shoggy
Das ist der Neue Hf, der läst sich nicht mehr an die AS xt anschließen.
Ce message a été modifié 3 fois. Dernière modification effectuée par "EnigmaG" (10 octobre 2012, 12:11)
mercredi 10 octobre 2012, 12:34
Stimmt, gar nicht drauf geachtet. Hab nur flüchtig aus das Bild geschaut :whistling:
He is right :D
pegleg
ac flow sensor
mercredi 10 octobre 2012, 15:48
i dont understand you said it shut on usb aquasuite 2012? well that is what i am useing is aquasuite 2012 sorry i didn't say that.did i order the wrong ac flow sensor,i will be ordering the aquaero 5 xt or pro but i dont know what is better?need help can this flow sensor work for now with my pump?
pegleg
mercredi 10 octobre 2012, 16:08
well how can i get it working,or if i can.is there some vidoes or some chart to read about this.this is my first time with watercooling
mercredi 10 octobre 2012, 16:29
Sorry my English is not good enough to writing this.
If the USB connected it should be in aquasuite 2012 under MPS
Ce message a été modifié 1 fois. Dernière modification effectuée par "EnigmaG" (10 octobre 2012, 16:32)
pegleg
mercredi 10 octobre 2012, 16:41
yes it is there but i dont get no reading like on that chart well the top chart
Ce message a été modifié 1 fois. Dernière modification effectuée par "pegleg" (10 octobre 2012, 17:35)
mercredi 10 octobre 2012, 16:53
1-5
EnigmaG a envoyé l’image suivante :
Ce message a été modifié 3 fois. Dernière modification effectuée par "EnigmaG" (10 octobre 2012, 16:56)
mercredi 10 octobre 2012, 17:51
looking good
make a new overview page with the flot oder adding it to the existing (Bild)
quod vide: 10. Overview pages aquasuite 2012 in the manual
Ce message a été modifié 2 fois. Dernière modification effectuée par "EnigmaG" (10 octobre 2012, 18:06)
pegleg
think i got it
mercredi 10 octobre 2012, 19:05
here is the overview page tell me if it dont look good enigmag or any buddy else.
mercredi 10 octobre 2012, 19:27
i do´t think 2gal/min is OK
it should between 0,1-0,6gal/min with theaquastream xt
pegleg
mercredi 10 octobre 2012, 21:35
ok will try to get it there
pegleg
mercredi 10 octobre 2012, 21:36
thanks,what would i have to do to get it down to them marks?
Ce message a été modifié 1 fois. Dernière modification effectuée par "pegleg" (10 octobre 2012, 21:39)
