• 22.11.2026, 21:28
Satyr
Antifreeze water additive for aquacomputer equippment
lundi 15 octobre 2012, 17:35
Hi!
Last year during Winter if I shutdown my computer for too long the liquid of my water circuit would froze because my radiator is located outside my flat. Is there an additive that I can be added to the distilled water + anticorrosion additive that would make it freeze resistant or lower the chances of it? If yes what and in which proportion?
Thanks ^_~
jpmboy
Double protect freezing point
lundi 15 octobre 2012, 21:36
What is the freezing point of DP?
AsRock E3Gen3, 2700k @4.6 with cuplex HF, 2 HD7970s with aquaC waterblocks, 16G GSkill 2133, TJ09, ST1500 ps, plextor 256 ssd, 2x1TB WD VRs raid 1, HP 30 inch. Aquacomputer 720XT Mk IV.
mardi 16 octobre 2012, 10:32
It fully freezes at -20°C but at around -10°C it starts to become jellylike.
I would not use it for the mentioned purpose.
Satyr
Double protect
mercredi 17 octobre 2012, 16:16
Does the DP has to be used pure or can it be mixed with distilled water or/and water colorant like glow motion?
jeudi 18 octobre 2012, 09:19
It can not be mixed. It is a ready to use coolant and not a concentrate.
jpmboy
Antifreeze
mardi 23 octobre 2012, 18:50
Satyr - what did you find to prevent freezing? Is automotive antifreeze compatible with PC WC materials?
mardi 23 octobre 2012, 19:13
You can use G11/G12 for cars. Besser doch kein G11 ?
Discussions similaires
