• 22.11.2026, 21:29
pegleg
need help on how to hook up my aquaero 5 xt
jeudi 18 octobre 2012, 22:20
i just got the aquaero 5 xt today how do i hook up my ac flow sensor and my aquastream xt pump to it? i think i know but want to make sure i dont mess it up..lol
vendredi 19 octobre 2012, 00:27
1.
.If
the connector is configured as aquabus interface, you can also select the
aquabus address of the aquastream controller. If for instance two aquastream
pumps are to be connected to a single aquaero, one pump has to be
configured as address “10” and one as “11”.
2. AE5 aquabus 2->4PIN Y
3. 4PIN Y-> 4PIN->Flow
4. 4PIN Y->3PIN Y-> 3Pin->aquastream xt pump
5. 3PIN Y-> 3Pin->aquastream xt pump
pegleg
hi again
vendredi 19 octobre 2012, 01:55
so i cant hook the aquastream xt from the aquabus\flow 3 pin to the aq5 xt aquabus 2,4pin will that work,they should give u them y sss..lol...and the aquastream xt will be hooked up to motherboard usb,then hook the flow sensor up to the aq5 xt flow,and then hook the aq5 xt usb to motherboard usb and if i need them y ss where can i get them in the states or where are they on aqua site could u give me a diagram on how to hook thse things up? thanks again all i have is one pump for now
Ce message a été modifié 3 fois. Dernière modification effectuée par "pegleg" (19 octobre 2012, 04:56)
vendredi 19 octobre 2012, 19:33
No, Not the new One.
pegleg
vendredi 19 octobre 2012, 20:27
ok, and it will have to be hooked up to motherboard to right
vendredi 19 octobre 2012, 21:35
you can hook the new flow sensor to usb and to AE5 aquabus 2, if you use a 3 Pin aquabus cable you must hook usb, too. If you use a 4 Pin aquabus cable you can hook usb, too
you can hook AE5, aquastream xt pump and flow sensor to usb
if you don´t have y-aquabuscable it´s best to hook the flow sensor to aquabus 2
Ce message a été modifié 1 fois. Dernière modification effectuée par "EnigmaG" (19 octobre 2012, 21:36)
