• 11.11.2026, 03:24
Psychor
AquaComputer MPS Flow Sensor 400 & Temp. Sensor?
lundi 5 novembre 2012, 06:20
Questions:
(1) Can the Aquabus cable (4-pin) used for the prior generation flow sensor be used with the MPS 400?
(2) Once the MPS is connected to the AQ5 via the Aquabus 4-pin cable do I also need to attach a cable to measure temperature? If so where can I buy this cable female to female 2-pin cable?
Thanks.
lundi 5 novembre 2012, 11:23
1.) I guess you confuse something here. There is only one 4-pin aquabus cable available. If you mean the high flow sensor (without USB/aquabus), it is using a 3-pin cable which is incompatible to the aquabus because of a different pin-layout and another plug on one end.
2.) There is no cable necessary. A sensor is already integrated to the mps.
Psychor
lundi 5 novembre 2012, 17:40
Thanks Shoggy but then what is the "TEMP" port on the MPS for? I thought another cable had to be run from that to the AQ5?
mardi 6 novembre 2012, 08:57
You can connect an additional sensor there. The only connection to the aquaero is the aquabus.
Psychor
mercredi 7 novembre 2012, 00:52
Great. Thanks Shoggy.
