• 09.10.2026, 23:37
WraithGTO
AQUAGRATIX HD 7970 and Sapphire Dual X 7970 compatability
dimanche 11 novembre 2012, 11:43
Gday
I was looking at buying 2 of the AQUAGRATIX HD 7970 water blocks, but I am not sure if they will fit my Sapphire 7970 cards
Does anyone know if the AQUAGRATIX HD 7970 will fit a Sapphire HD 7970 Dual X OC . It has a SKU 11197-03-40G.
I believe it is Similar to a reference card but with a few slight changes. eg there is a extra row of caps to the rear of the card .
Here is a link to the Sapphire Card
http://www.rwlabs.com/article.php?cat=&id=708&pagenumber=5
Cheers
lundi 12 novembre 2012, 09:40
If you card looks like the one from the mentioned link, then it will not work since this card has a different layout.
WraithGTO
lundi 12 novembre 2012, 14:56
Thanks for the info Shoggy.
Can you tell me what and where please on the 7970 DualX OC Blue PCB variant. That will make the AC block not fit please.
Cheers
mardi 13 novembre 2012, 12:20
Just compare your card with the photo of the card in our shop and you will see a lot of differences. That is nothing that you could modify.
Jakusonfire
vendredi 16 novembre 2012, 12:50
This thread explains the problem. There are two versions of this card.
http://forums.overclockers.com.au/showthread.php?t=1059050
Ce message a été modifié 1 fois. Dernière modification effectuée par "Jakusonfire" (16 novembre 2012, 12:51)
