• 14.10.2026, 03:20
Psychor
Aquasuite 2012 Release 1 & Master/Slave?
mercredi 14 novembre 2012, 04:46
So if I own (2) AQ5 Pro units I can set one up as a MASTER and the other up as SLAVE and they would all work together? I currently have one (1) AQ5 Pro and (4) PA2 connected to one another. I could essentially replace the (4) PA2 with another AQ5 Pro?
Thank you.
mercredi 14 novembre 2012, 08:08
Only a aquaero 5 lt can updated with the slave firmware.
If you have a aquaero 5 pro, you have to dismount the lcd.
When you have flashed the aquaero 5 lt to a slave device, you can connect both devices with a aquabus cable.
Psychor
mercredi 14 novembre 2012, 21:40
Thanks Sebastian.
ssurfer
jeudi 15 novembre 2012, 23:19
Just to make sure i've got things right regarding master/slave connection:
1 - change LT firmware to slave
2 - disconnect LT USB cable
3 - connect XT's high speed aquabus port to LT's high speed aquabus port
Also can i use one of the 3-pin aquabus cables that came with the devices or should i get the following one?
http://shop.aquacomputer.de/product_info…roducts_id=2846
regards
ssurfer
jeudi 15 novembre 2012, 23:31
Also,
Aquasuite page states that after going to slave mode LT will provide 4 fan channels + 4 sensors, what happens to the remaining 4 LT sensors?
Bottom line i'll have 8 fan channels + 12 sensors, is that right?
regards,
vendredi 16 novembre 2012, 07:07
the other hardware from theslave aquaeo is not used.
You can connect the aquabus with the 3 or 4pin cable.
ssurfer
samedi 17 novembre 2012, 17:54
just changed the system.... LT is now is working as XT's slave.... later i'm reconfiguring the whole thing... for now i'm wondering how are future updates going to work? will it be possible to upgrade LT through XT? that would be ideal but i can't find an option for that in Aquasuite current version.
1 bug found so far: LT's PWM fan port is being detected as a regular voltage controlled port
samedi 17 novembre 2012, 19:05
this is not a bug.
All slave outputs are only voltage controlled.
ssurfer
dimanche 18 novembre 2012, 00:29
is this a design limitation or it might be changed in future aquasuite versions?
mercredi 21 novembre 2012, 15:15
That will not change in the future. We just had to set a limit for the possible functions to keep the development costs at a reasonable level and also not to compete against ourselves.
