• 09.10.2026, 14:12
jpmboy
Is there a changelog for the new AS2012RC1?
mercredi 14 novembre 2012, 20:58
Before downloading and flashing the firmware... What are the operational improvements/benefits for users?
AsRock E3Gen3, 2700k @4.6 with cuplex HF, 2 HD7970s with aquaC waterblocks, 16G GSkill 2133, TJ09, ST1500 ps, plextor 256 ssd, 2x1TB WD VRs raid 1, HP 30 inch. Aquacomputer 720XT Mk IV.
Namron
mercredi 14 novembre 2012, 23:27
Is this what your looking for?..
The translation has been done using Google, So excuse the mistakes. (sorry I don't speak German)
With the aquasuite 2012 Release version the more than 1 year and 16 permanent beta versions of aquasuite 2012 was terminated. The new version has now once again an extremely large development to the last beta version. The new version is also adapted for Windows 8, and now compatible.
On the device, the aquaduct and eco-per-received series in the aquasuite 2012th Thus, with the aquasuite 2012, the following devices are managed:
Aquaero 5 • xt, and per lt
• aquastream xt
• aquaduct xt series mark IV
• aquaduct eco / per series
• poweradjust 2
• mps-series: flow, pressure and level sensors, High Flow USB, Aqualis sensors and the USB-D5 pump
• tubemeter
A short screencast of aquasuite 2012-1 we would like to share with you:
http://www.youtube.com/watch?feature=player_embedded&v=MUsFbIeACAQ
http://www.youtube.com/watch?v=HJ1Da4V4_G4&feature=player_embedded
http://www.youtube.com/watch?feature=player_embedded&v=uaqYG_DSbnQ
Of new features, the complete evaluation of the log data of all equipment has been integrated. This allows all kinds of configurable and create reports. Here across devices, all data will be compared with each other (eg temperatures of the aquastream with fan speed from aquaero). The reports can be exported and saved. In addition, the superego pages are accessed live on the evaluations and this thus also be used here with a special control. These ads are always updated live, eg , the last hour or the last day will be displayed.
One of the most important new features is the ability summary pages display on the desktop. For this purpose, in the edit mode of a folder page appears when you enable the desktop features as the current desktop background. Then you can arrange the controls as normal and as design for the desktop semitransparent. Then by leaving the edit mode, the page will appear on the desktop. The plane is directly over the icons, but this could by visualizing the aquasuite pass be used normally. With this addition, you can create your own in a few minutes for the desktop gadget!
The processing of the overview pages has been expanded dramatically. There are now copy / paste functions, simple to change the size and position, and new controls, eg Pointer instruments. In addition, significantly more properties are accessible. Also, the structure and the export controls has been expanded. Also, groups of elements can now be exported and imported, and their properties are processed simultaneously.
Significant improvements were also at the level management and the handling of properties. The current structure of the data elements has been improved so that it will remain from now compatible for the future and even in the text editor is easy to read (XAML). The exchange of items between users is also now very easy.
As an extremely powerful new feature is a built-in code editor now directly XAML code can be written and edited. For this, we provide access to the data sources and special Converter. There are also examples directly to e.g. Share pictures for values ​​of variables or display animations in certain states.
In order for new updates and information to always be up to date, also an RSS reader for a dedicated channel for aquasuite was integrated. Here, we will send new updates, enhancements, and information about equipment.
Overall, the 2012 aquasuite many other advanced functions and is a significant improvement to the beta versions. Many small bugs have been fixed. For aquasuite 2013 we plan to implement some other major functional areas and a first beta in early 2013 to provide.
In the firmware, there are many small improvements big news for the aquaero: Here you can an aquaero lt umflashen now a slave aquaero via firmware update. Thereafter, this can serve as an extension for Aquero and are connected where aquabus. Through this expansion are the master aquaero then 8 fan channels and 4 additional temperature sensors.
For aquaero 5 and the mark IV aquaducte now, the internal log data can be read. These are synchronized with an intelligent function to the database of aquasuite. So must the aquasuite to capture the log data is not always in operation. In addition, the event logs (alarms, status reports) of the devices now be read and displayed in the aquasuite!
When aquaero aquaduct and the functionality has been extended in the overview pages long. The new aquasuite can own pages to be loaded into the aquaero and special pages for idle and standby are defined. In addition, the lighting is now activated in the event of an alarm.
Below detailed list of all the important changes and new features:
Logdatenmodul for all devices enabled:
• Live-export any data as XML or as a shared memory file
• Cross-log configuration of all devices present in the total system data
• Evaluation of the data in the aquasuite
• Reports can be saved and can be integrated into the summary pages
Overview pages:
• All elements can now be easily configured
Revised • All settings dialogs
• Edit mode is now activated directly via the navigation (lock icon)
• Controls the possible selection by mouse, or hold down the Shift key
Mouse: select from left to right -> Only items within the selection
Mouse: select from right to left -> intersection of the elements with the selection
Mouse: Hold down the Shift / Ctrl key, the selection is possible via existing controls
• Elements that are selected, have a border.
• movable elements as a group.
• Elements can be changed using the mouse in size.
• Import the context menu outside elements, export and copying of elements
• Elements can be copied between the overview pages.
• Group functions for delete, move, copy, paste, and basic properties of the elements.
• Several properties selected elements can be changed simultaneously. Modified properties are applied to all selected items
• The overview pages are now stored in an easily readable format XMl.
• Revised Custom Element:
• Several templates for possible elements with simple examples
• Data connection to device data possible
• New code editor to directly edit and check the XAML Controls
• In Edit mode, the following keys are used:
Ctrl c / v: Copy / Paste
Enf: Delete
: New Item
Cursor: move in increments
• Double click on an item now opens directly the settings dialog
• Bar graph: Now horizontally and vertically.
• New Control: Meter:
The gauge can be made very clear. In addition to the colors and fonts can scale values ​​(major and minor scale) as well as the size and shape and angle of the display are shown. In addition, the previous display area are shown (statistics). Another scale can represent color marked areas.
Desktop
• overview pages are displayed on desktop
• Direct editing on a copy of the desktop background enables accurate placement
Specific changes to individual devices: [*] aquaero 5 & mk4 aquaduct
Current Alert is now available for the overview pages
System Stored messages are now viewable from the aquasuite
Log of the device can be configured and used
Log data can be synchronized with the internal database of aquasuite
Fixed a bug in setting the curve controller
Slave firmware for aquaero lt, so it is possible a aquaero 5 operate as a slave by aquabus
The slave aquaero 5 identifies as poweradjust 1-4 (Fan Channel 5 .8)
Additionally, the temperature sensors are transmitted from the first slave .4 aquaero
LED controller adapted and optimized power output LED
The backlight comes on the active brightness when the alarm level is> 0
Configurable page for the idle and standby state.
If you can not operate the unit automatically selected page is displayed.
Changes profiles (only aquaduct, aquaero 5 per xt and usable)
It is now always loaded after starting the first profile,
About the event or on the device itself, the profile can be changed
• aquastream
Switching aquabus / flow sensor: Fixed
That was roughly. We hope that the software works well with you and ask for feedback. Bugs should still occur, we will resolve the very short term (on the small official channels). Just the desktop functionality is very complex because there are many different versions of Windows with different behavior (from XP to Windows 8 has done quite a bit ....).
The aquasuite you find in the usual place in the support area.
Have fun test!
Hope this helps..
N.
jpmboy
jeudi 15 novembre 2012, 03:01
Excellent - Thanks!!
