• 11.10.2026, 08:46
hrmes
Incorrect RGB LED color with latest firmwares
vendredi 30 novembre 2012, 17:35
After updating the firmware of AQ5 XT to 1026 and then to 1027 I noticed that the colors of a RGB LED that I have installed in a case fan looked a bit different than before.
After looking at the settings of the LED controller I realized that the current RGB LED values at a given temperature seem to be incorrect.
For example in the attached screenshot at a temperature of 32 C the blue LED value should be less than 20%, yet it is at 31%.
The green LED value should also be less than 80%, but it is at 87%.
Anyone else with incorrect LED colors ?
Edit:
Why not use curves in the LED controller like you can for fans ? Thay way you would have much more control over the color hues.
hrmes a envoyé l’image suivante :
Ce message a été modifié 1 fois. Dernière modification effectuée par "hrmes" (30 novembre 2012, 19:02)
lundi 3 décembre 2012, 09:59
In some way it is correct because internally we use a logarithm which converts your settings to another curve so you get a linear change of brightness to your eyes.
We will have a look if we can adjust the shown values in some way so it is less confusing.
hrmes
lundi 3 décembre 2012, 12:17
It seems that the current interpolation method is spline-like. There could be an option in the firmware to use ordinary linear interpolation that would produce a more predictable set of values.
Discussions similaires
