• 19.11.2026, 01:34
darthsyth
More newbies question about the aquaduct Mark IV
lundi 17 décembre 2012, 22:07
First I'd like to say that everyone on this forum have nothing but helpful and nice. So thank you guys for all the help and fast responses.
And now to my newb question: Would it be bad for the Mk IV system if I was to add another pump within the water cooling loops, to increase flow?
mardi 18 décembre 2012, 10:22
The is no problem to integrate another pump into the loop. I would avoid to use a pump with a MUCH higher flow rate than the aquaducts pump.
jpmboy
jeudi 20 décembre 2012, 03:21
Darthsyn - Shoggy helped me with this earlier this year. I looped in a Liang pump - it works fine. There is a kit:
http://shop.aquacomputer.de/product_info…roducts_id=2483
I bought the DCC pump and poweramp, looped it in with high flow quick disconnects to the outlet of the MkIV. In my case the the base of the MkIV is about 1 meter below the first cooling block... went from 40 l/h to 60-70 l/h with the DCC at 9.2V. For me, the main purpose was to put a backup/redundancy into the system.
AsRock E3Gen3, 2700k @4.6 with cuplex HF, 2 HD7970s with aquaC waterblocks, 16G GSkill 2133, TJ09, ST1500 ps, plextor 256 ssd, 2x1TB WD VRs raid 1, HP 30 inch. Aquacomputer 720XT Mk IV.
Discussions similaires
